Squiggy's 2012 DBP II Si Coupe
Looks better then what i have at the moment. I may try to go back further. I have been havin a slight drop in tpedal in my logs higher in the rpms even if my foots to the floor. I think this is the culprit. Thanks for the pics
It will be really tough to go back any further. Just make sure you wrap the wire with electrical tape before dropping them through the cover with the others and run it behind the coolant hose as seen in the first picture. That is how I managed to get a little slack.
Your adapter looks a lot thinner then mine too.
Speaking of, it is already a tight fit with the hood prop. Adding a P2R thermal gasket could be an issue. We need hydraulic hood struts!
@323 may be interested in this tidbit.
Uploading the basemap from Vit and about to go for a data logging drive.
Always exciting doing a 3rd gear pull. Have fun. THe parts for the rbc install haven't showed up yet for the 13 FB6. I will make sure to do this. I may also do one for Coilovers.
No third gear pull yet. He wanted 15-20 minutes of "light" driving.
On order:
Well, mod purchases are coming to an end until spring. Except for a set of front speakers/tweeters and taking advantage of a free shipping sale from @CollegeHillsHonda if they do one before spring. Just have to finish installing and tweaking everything and then just enjoy the car for a while.
I hear you there. Im completely done for a lonnnnnng time. Lol. My new mod is going to be paying off the car. Lol
I don't believe on anything you just said. :giggle:
The car really turned into a beast of a project very quickly and unexpectedly. Even though I am "done" until spring, I need front speakers, parts for a headlight retrofit, angled zerk fittings for the RSB bushings, and anything that pops up for finishing the stereo install. :confused:
There's no such thing as being 'done.' I thought I was done buying stuff for a while, but then I bought more suspension stuff lol. I bought something else a couple nights ago, and now I plan on buying something to spruce up the exterior appearance if it can be shipped here for a decent price.
You call that 'a beast of a project'? :confused:
Have you seen the INSIDE of my car? Not to mention all the other stuff going on at the same time? Not implying the car is going beast mode, just that I did a whole hell of a lot of stuff to it since spring and wasn't expecting to really do anything. It has been very costly and time consuming.
Reactions: 323
Just finished my fourth datalog with Vit.
