- 2,883
- 2,375
i think i got the right part number
@Michael Hurd : What paint do you recommend for refinishing wheels, short of baking them?Just to let you know.... most every high heat paint I have used does not cure until high heat has been applied, IE: will be sticky without baking. The solvents evaporate, but it doesn't cure. Also, this makes a poor finish coating IMO for salt resistance.
If you are dead set on using it, you must find a way to bake it.... however the household oven isn't a good idea.
I know its mid-January, but I finally found a good deal on a set of four snows: Nokian Hakkapeliitta rsi 225/45/17 with 3k miles on them. I'm using the '12 Si rims for winter use. got an extra set of tpms sensors a while ago for this purpose. Now I don't care (much) if it snows.
Happy to oblige!That's great news. You do know that because you bought those it's not going to snow anymore right? You've done us all a favor. Thanks!!
If you can get a local paint store to make up a spray can with an acrylic enamel, this will generally be a tougher paint than most over the counter spray cans, plus you can get it made in a variety of colors, or an exact match for an OEM color if desired. The resins are of a better quality, and stronger solvents as well to dissolve the resins. Pigments are also going to be stronger than most cheap spray cans, meaning less coats to hiding.
2 component paints ( with a catalyst ) are tougher yet, especially urethanes like BASF's RM UNO-HD line or Dupont Imron. However, these paints aren't for sale or use for the general public as the isocyanate catalyst is toxic and can cause respiratory issues.
With any paint, proper ventilation is key.
 i got them for such a good price i couldnt pass it up
