Try to find it, & tighten just a little to see if it stops(don't want to over tighten). It can also be something in the muffler, or some part of the pipe end the way it was built, thumping on it should bring it to light. Also check the headers at the manifold(torque wrench only).Alright, sounds good. Once it warms up I can look under to see. If it is a connection should i just tighten it up?
Like the above posted heat shields and connections. Are you using the silencer?My exhaust is making a buzzing noise at around 2000 rpm, more noticeable when going uphill. I've got a TSUDO catback for the LX.. Anybody know of any hot spots the exhaust could be rubbing against?
I dont have the silencer in so it couldnt be that piece.Like the above posted heat shields and connections. Are you using the silencer?
I beleive its two pieces. One piece is straight, the other has the resonator on it.do you have a solid mid pipe or a two pieces that slide together that a clamp goes over?
YEH... Just start tapping on suspected parts..........I dont have the silencer in so it couldnt be that piece.
Even though the LX dosent have an exhaust cutout, the end dosent seem to hit the bumper at all. I have a feeling it might be rubbing against one of the metal heat shields because they are really close to the exhaust after taking another look, like NeoKaido said.
yeah its most likely that, after looking back under its really close to the pipe and i'm pretty sure that's whats making the noise. Ill probably just find some way to move it arounddid you check your heat shield? People always forget to fix that haha!
there is another sheet of metal there that comes down around the back end of the cat. i bent mine with channel locks and i haven't heard a peep since :PHey guys i just got my full race catback(which by the way im in love with) and i have some questions....I just installed it yesterday and i fixed the heat shield rattle but now its tapping against something when i hit a bump and stuff like that? Now i wanted to point out that i did notice it was super close to some little metal piece close to where the cat is?! Im thinking its tapping against that and was wondering if anyone else has this problem i have the 2013 sedan and when i looked at the undercarrage picture of the coupe on the fullrace site i noticed it doesnt have that metal piece i have!
Do you happen to have a picture of it? ima put my car on the lift here at work and take a picture so yall can see what im talking about!there is another sheet of metal there that comes down around the back end of the cat. i bent mine with channel locks and i haven't heard a peep since :P
i can almost guarantee if you were to lay down behind your back tire and look at the exhaust you will see a part of the pipe that is shiny from the spring hitting it. mine did the exact same thingHey guys i just got my full race catback(which by the way im in love with) and i have some questions....I just installed it yesterday and i fixed the heat shield rattle but now its tapping against something when i hit a bump and stuff like that? Now i wanted to point out that i did notice it was super close to some little metal piece close to where the cat is?! Im thinking its tapping against that and was wondering if anyone else has this problem i have the 2013 sedan and when i looked at the undercarrage picture of the coupe on the fullrace site i noticed it doesnt have that metal piece i have!
