iShift_6
Let me preface all this with I'm no electrician or electrical engineer.
Just a guy with a volt meter and way too much time on my hands.
With that said, here goes my first attempt at a DIY.
First thing I did, that will spare everyone else time, is buy both harnesses
and do a pin for pin comparison. See below.
Although you guys might want to have a donor Si harness around so you don't kill your stock one.
Si Harness Below
Hybrid Harness
With that in hand I went after labeling every connection to figure out what was what.
Did this by matching up connectors that would be the same on both cars and working
backwards from there. See difference below
Si Harness at Tail Light Ends
1: Turn Signal
2: Running Light (3 little LEDs)
3: Brake Light
Hybrid Harness at Tail Light Ends
1: Brake & Running Lights
2: Turn Signal
Those are the main connections.
There are other difference, but those are coming up.
Here are the harnesses side by side and the connections that need to be addressed
Highlighted section is where all the magic happens.
The upper harness is the Si, notice the extra white connection.
Hybrid Harness on Left
1: LED Running Lights
2: Reverse Light
Si Harness on Right
2: Reverse Light
3: Running Light
4: Third Brake Light (Spoiler Light)
Detail of the Si Harness
1: Reverse Light
2: Running Light
3: 3rd Brake Light
Si Harness Below
Hybrid Harness
1: Turn Signal
3: Brake Light
2: Turn Signal
2: Reverse Light
Si Harness on Right
2: Reverse Light
3: Running Light
1: Reverse Light
2: Running Light
3: 3rd Brake Light
