They are in satin black just like bottom pieces. The color match ones are very bore. All current civic have them. I like everything to be matched not half and half.are they a glossy/satin black? Didn't like the color matched ones?
I think my is 17x7 also. How do you like these spacers so far?I have the same spacers only they are 15 mm. Will be putting them on in the spring.
What size are your tires? 7" 8" or 9"? Mine are 17 x 7".
Thanks.
I just noticed you have the Beeks tie bar. I have it too, but not installed yet. Did you notice a difference after install?
Beaks style lower tie bar to be honest, it's more like for looks.
did the wheel spacers fit flush? i'm going to need some for my new wheels. i been searching on the forums for an answer but im not to good at searching. All i'm asking is, will i need to cut my stock studs if i run a 20mm spacer?
Yes, they fit flush. No need to cut stock studs at all!did the wheel spacers fit flush? i'm going to need some for my new wheels. i been searching on the forums for an answer but im not to good at searching. All i'm asking is, will i need to cut my stock studs if i run a 20mm spacer?
