jsyn77
Moment
Gotcha. I was looking at the HD900/5 but couldnt justify spending $1300 for an amp when 2 would be a 1/3 of the cost. In the future i may look into upgrading but for now this should be enough of an improvement to satisfy my earsI checked the specs. The JX series do not list compatibility with diff balanced inputs. The JL XDs do. You are running your 500/1 after the factory amp using the subwoofer harness in the trunk. That is completely different than removing the factory amp and using the diff balanced outputs directly from the head unit.
Something like a LC6i?You might wanna bypass the factory amp with a dsp. That's was the route I plan on going. Just finances and time seem to be preventing it from happening at the miners.
I know JL makes the clean sweep dsp too. There is no shortage of options for improving factory sound quality but I havent looked too far into this side of aftermarket audio. I might have to reconsider jumping to the HD900/5 if things dont work out with the 2 JX amps post stock amp. Not ideal, but should be an improvement which is all I'm looking for at the moment.I think the lc6i is more geared for boosting and tweaking from a powered source. Like using hi level inputs on an aftermarket amp. I'm no expert. I'm gonna go with the deq-8 from ppi. You tap in the preamp wiring from the radio and you plug in your laptop and you got 31 band eq plus parametric I think. I'm not at a computer right now so I can't get all the correct numbers and features for you. But is has outputs to the amps you do use and you can really tweak your system. Plus output voltage is like 4-8 volts per channel so you don't need much gain on your amps. There are other dsp units out there. I think Rockford Fosgate makes one to that's suppose to be awesome but too rich for my budget. This is all info pulled from the top of my head so you might wanna do some research on it to see if it's more to your liking.
Whoops I probably should've mentioned that huh? LOL I have the 2012 Si non Nav system. The only frequencies I really care about for the sub is 80hz and below so no real need for full range. My sub is and box is slot ported for 35hz sweet spot.
Lol, good news is that you will get at least 300hz from the sub preamp, at least thats what I heard until I adjusted the crossover to 100. You can do what I did, make a rca preamp from the hardness in the back of your imid. I recall getting 2.5v+/- 0.5v from the preamp. connect that to the amp and run the rest. Only hard part is making the harness. It took me a bit longer because I ran wires to have my amp to be tucked under my seat and my sub hidden.
