You will not be within oem specs with the sportlines. Some people have done camber kits and others haven't. All depends on how much you care about tire wear or negative camber.
I plan on getting a set of SSR GTV02's.It's personal preference but I would suggest getting them. What wheels are you trying to run? It may be necessary to dial in some negative camber to fit the wheels if you want to run something very wide. Doing fender work is one way to avoid running excess camber though.
What is the overall setup you are trying to run?
haha... thanks bro, but far from a baller. gotta get entry-level rims because i can't afford forged or 3 piece wheels.Baller!
what width do you recommend? i don't want to stick out of the fender. what width are the rims on the '14 stock wheels?Nice looking wheel. Got a particular size in mind?
as far as size goes, i was thinking 18's.
Thanks bro... That's how much of a rookie i am. It's still a lot of money, but I will say this, $300+ /wheel for non-forgeed wheels is still better than $600-$700/wheel for forged.SSRs are nowhere near entry level.
The stock 18s are 7.5" wide, I believe. If you stick with the 45mm offset, you can run 8" wide wheels.
