stormCIVIC
Happy 3rd Birthday to stormCIVIC.
true but im saving for eibach anti sway kit. front and rear sway bars.The JDM hazard light button would look perfect in your dash. Easy to install.
.....and wheels too. Haha. Ya, you've got your priorities straight.true but im saving for eibach anti sway kit. front and rear sway bars.
The rear is 19mm.true but im saving for eibach anti sway kit. front and rear sway bars.
How much is it and give me a link to buy.....and wheels too. Haha. Ya, you've got your priorities straight.
I don't think you need the front sway bar, only the rear one from all that I have read. The Progress one is thicker than the Eibach one.
Yup, just get the rear if you want the car to handle better. The front will make it understeer even worse and cancel out the improvements from the upgraded rear.
EDIT: The car will corner flatter but not necessarily better with the front.
im getting the rear sway bar from eibach. its cheaper. so i hope you guys are right on not needing the front upgraded.The rear is 19mm.
You might as well just get the rear 20mm 2014 Si rear sway bar that only costs $40.
im thinking of getting the godspeed 24mm rear. its bigger than both progressive and eibachThe front absolutely does not need upgraded, but you should really consider the 22mm Progress over the smaller Eibach.
haha.no not cheaper than that. I have three choices here. 22mm progressive for $199. 24mm godspeed for $170. or OEM si 20mm for $40.The 19mm Eibach rear sway bar is cheaper than the $40 2013+ 20mm Si rear sway bar?
I'd recommend the 20mm bar for an overall best value. Ditch the Godspeed sway bar.
yeah i know but i like the 22mm. where doyou find the $40 si sway barProgress has them in both sizes (22mm and 24mm). Godspeed replicated the adjustable 24mm with the adjustable endlink.
