twelch830
OK so pre amp rca splice into rockford bld. Sounds good thanks man
You should not need to use an LOC because the signal is already a pre-amp out from the head unit. However, you need something to handle the differential balanced output, which might be the Rockford bld you are referring to. I am not familiar with it, so do your research on that product. I used a JL Audio 5-channel amp which accepted differential balanced outputs from the head unit without any converters needed. I got excellent sound from all four channels, including solid bass from the 10" subwoofer. I enjoyed my stereo upgrade for a year until I got rid of the car.OK so pre amp rca splice into rockford bld. Sounds good thanks man![]()
The Infinity Kappa Five amp, which is a 5-ch amp, is compatible with differential balanced inputs. Crutchfield no longer sells Infinity, but here is the old link to the amp. http://www.crutchfield.com/S-WEA7iVnN6E1/p_108KAPPA5V/Infinity-Kappa-Five.htmlHillstones,
Do you happen to know any other amps besides the one you purchased that would furfill the requirements for a straight swap?
Those amps wont work. You need a HD or XD series JL amp. Those are the only ones that accept differential balanced inputs. The 360/4 is a JX series. I mistakenly bought one to use for my car thinking it accepted differential balanced inputs and had to return it.Hillstones,
sorry to pester you but if i can find a jl audio 300/4 amp u think that would do the job?
or JL Audio JX360/4
and does full range amp translate to balanced differential inputs? or do they need to state that in the details. appreciate the help
appreciate the inputThose amps wont work. You need a HD or XD series JL amp. Those are the only ones that accept differential balanced inputs. The 360/4 is a JX series. I mistakenly bought one to use for my car thinking it accepted differential balanced inputs and had to return it.
Before for differential inputsDo you splice after or before the factory amp?
Do i need to add a crossover for the tweeters?Before for differential inputs
I have one that came with my speakersDo i need to add a crossover for the tweeters?
Get component speakers for the front and coaxial for the rear. You'll get better sound and it's easy to install the tweetersi am going to get coaxial speakers and keeping my stock tweeters. not sure if i just splice in a crossover or go back to the factory amp then use that to power the tweeters.
You can't go back to the factory amp to power the tweeters because you are removing the front channel inputs from the factory amp. Buy component speakers for the front. The factory speakers in the Civic are garbage, and so is the amp.i am going to get coaxial speakers and keeping my stock tweeters. not sure if i just splice in a crossover or go back to the factory amp then use that to power the tweeters.
