Pauly99to17
Thanks Darkout. Appreciate your input. I will try your suggestions.
it has a 64.1 boreThe Acura CSX Type S wheels have a bore diameter of 64.1 mm. I'm pretty sure the hub bore for the 2012 LX sedan is also 64.1 mm. Can someone confirm this?
You are lowered right Pauly? Springs can be made where the coils touch like in the pics, shocks don't support any weight its all on the spring. Oscillations up and down are what burn out shocks and with a car lowered on factory shocks can wear out faster but that's felt as a bouncy ride more so. Every tire will have some various oscillations when spun, to me if one spot was particularly "protruding" as it's spun then i may be suspect about the ride quality.
