Drag slick setup
Kevv_Si
1,508
757
Indianapolis
Si
FB6
After a lot of searching I've finnally ordered my set of drag slicks and thought I'd leave the specs here for anyone else that might be looking in the future. Note: if you run this on stock caliper you may need to shave them a little to clear.
M&H Drag Slick - 8.5/24.5-15 with Rota slipstream 15x8 (5x114.3+ 40mm 73 Hub
I thought the Rota Slipstreams in that spec is discontinued. Did you get them used? I've seen this setup on a FG2 and the fit was so tight!
M&H race masterdrag slicks
24x8.5x15
Circle racing wheels... He had to use 25mm spacers
I believe @axion_industries have a drag setup on their car. They could probably chime in with some pointers/options/advice as well.
