how long until OP comes back to see if he got an answer.....
@Nix the guy was running D2 coils not springs. Not sure where he went but I'm faced with the same rubbing in the front problem.aaaannnnnnd.... months later I guess the guy is still running cut springs and rubbing the stock wheel setup with maybe rolled fenders.....
@Nix the guy was running D2 coils not springs. Not sure where he went but I'm faced with the same rubbing in the from problem.
Now I haven't had the alignment done so I don't know what the camber is on the front but it rubs once in awhile. I was looking at it tonight after work and thinking I might raise the front 1/2".
I'm curious what everyone else that has lowered their car has done to prevent this other than removing the fender liners.
When I had my Eibach Sportlines springs installed (close to 2" drop) it also rubbed at the front sometimes. At that time I had factory 18" wheels on.Currently there is no wheel gap @Michal006 so it's seems to me that unless I run more camber I have to either raise the from a little more or try running the dampers a little stiffer.Are you slammed?When I had my Eibach Sportlines springs installed (close to 2" drop) it also rubbed at the front sometimes. At that time I had factory 18" wheels on.
That's exactly what I did @NixThe fender liner is held in by metal tabs. If you are rubbing on the tabs you can bend them up slightly, remove the liner clips, and tuck the liner behind the tabs to hold it in place. Should give you a little extra clearance if you only occasionally rub.
