OffTheWall
Advice needed? What's the easiest way to remove the gray trim on the door panels? Trying to vinyl wrap the, ('13 sedan)
curious what kind of vinyl/material you were using? There is a big difference between brands and actual model #'s on vinyl film.Thx
I got everything off except vent trim. I can't wrap for sheets. Tried wrapping emblem and grey door handle. Epic fails.
did you use a heat gun to help mold it? Check this out as an example on a curved itemVivid vinyl. It's the contour on the corners of grey armrest handle
View: https://youtu.be/0aV2H57bES4
what color are you wanting it done in?I did ! No hope! Lol. I believe it's the color I chose. Very unforgiving. Can't even find this color from 3M. I wrapped my 12's stock and forearm with mossy oak vinyl and that was real easy!
