chucksomerock
- 30
- Vehicle Model
- Civic EX
- Body Style
- sedan
Hi, I'm trying to remove the coolant drain bolt in order to make a block heater installation.
The bolt seems stuck on th engine block. I have tried with a 3/8 ratchet with extensions and even ended up making a series of attachment in order to use my impact drill... I also sprayed wd40 in order to loosen the bolt.
Did soneone here one removed that drain bolt? If so was it hard to remove on your car?
Thanks
Thanks
