You have a simple volt meter to check DC volts? Check the voltage at the battery terminals when the car is running and you should see 13.5-14.5V. Anything under 13V is kinda weak and more than likely your alternator isn't charging or the ECU isn't seeing that the car is charging. That message is related to not seeing the proper charging voltage if I had to guess.
