- 56,907
- 24,204
dual blow off valve setup? Turbo info?
Dual Wastegate. Dual Dumps. Precision 6262. Should make 500whp (Mustang Dyno) on 26psi. Same boost I'm running on my stock turbo making 316whp. Should be fun until I blow a hole in my block.dual blow off valve setup? Turbo info?
I'm probably making it sound worse that it is. Haha..... and you're ok with that prospect? Wouldn't it make more sense to build it prior to avoid unnecessary expenses?
Traded the Rex in for an Evo. Haha. While ago.the struggle of subie vs Honda lol. looks great enjoy
Yeah. It's a great platform, but does require a lot of work outside of bolt-ons.It makes me sad that they axed the evo
Yeah that's why I love my st. Bolt on put me at the power range I want to be at then down the road I can go big turbo on stock internals with no issue (for my goals as a daily driver)Yeah. It's a great platform, but does require a lot of work outside of bolt-ons.
Just make sure to avoid WOT in sixth. Those Eco's are popping left and right because of the heavy loads in higher gears.Yeah that's why I love my st. Bolt on put me at the power range I want to be at then down the road I can go big turbo on stock internals with no issue (for my goals as a daily driver)
I haven't really seen much on our forum of it but I make sure to down shiftJust make sure to avoid WOT in sixth. Those Eco's are popping left and right because of the heavy loads in higher gears.
Just for you. I'll give my neighbors your info.No revvs? Sounds pretty bru at idle.
Depending on which direction I go next year, I may ditch the air for some D2 Drag Spec Coilovers. Air is pretty nice though.HellaLow
