Action technology MI424WR Rev 1. And yes it is a modem router combo.so it's a modem/router combo? If you get the model # off of it, I could potentially help you.
ran through all this. Says udp port 3659 conflicts with something EA ralated. It let me open all the other required ports though.
It wouldn't let me. It says it conflicted with another rule set by ea. The servers were down so I couldn't test to see if I fixed any of the issues.Did you forward 3659 also?
How did it not let you? Were you in the game when trying to port forward? Exit out of anything game related. You shouldn't get any errors when port forwarding.It wouldn't let me. It says it conflicted with another rule set by ea. The servers were down so I couldn't test to see if I fixed any of the issues.
I just now got it to work. I had to disable the existing port foward for the ea tunnel for UDP 3659 and then reset it to foward just for my PC's IP adress. After that I was able to log in and get into a match.How did it not let you? Were you in the game when trying to port forward? Exit out of anything game related. You shouldn't get any errors when port forwarding.
What's you origin name. I may be on later as well.I should be on later tonight
How many you have lol?
Don't know. Just like ******* with you. I don't have my FPS in view while playing. If I do I use the in-game command and it shows up in the right corner.
Hit ~ then type perfoverlay.drawfps 1 (don't forget the space between drawfps and 1)
