najib
- 15
Am planning on getting window visors. The ones am looking at seems to only use 3m tape to hold it. Is that enough? Don't they require hardware?
Thanks for the detailed info really appreciate itI put some 3-M visors on my Jeep and they stayed in place for 18 years...........
I did the same with my 2012 Civic, which have been on for over 3 years.......
To properly install them you want to clean the area where they will be adhered, ***Then go over that area with rubbing alcohol***, then only apply visors in a warm(75 degree+) climit controlled environment(or substituted with a hair blower). Then after installed, you want to go over it inch by inch with something like a rubber mallet(not to hit it), to use as a press in your palm(better than using your thumb).
Another thing prior to installing, is to go over the edge of the tape with a black magic marker so the white edge won't show after install.
