2012 Civic Si coupe - aftermarket speakers
ChoyAxxx
84
26
Guys, I'm thinking of upgrading my stock speakers. Have a front and back set of Focal speakers. Will also add a 5 Channel Amp to the setup. Can i run the stock sub to the amp? Don't wanna add a box in the trunk. Need the space. Lastly, do you recommend changing the head unit as well? I was hoping to keep the stock HU as well. I'm a noob when it comes to these things. Just want to listen to clean and clear tunes. Thanks
Sent from my SM-G935T using Tapatalk
Forgot to mention i have the Premium Audio without Nav setup. Thanks
I think others have but complained about bass. I know at least a few did shallow depth 8" diameter subs in place of the stock sub and said it was significantly better. Most have done boxes though.
Yeah. I would go with the box too but I don't wanna lose my trunk space. Lol.. Do you know what 8" sub fits the rear deck?
http://9thcivic.com/forum/threads/2012-civic-rear-speaker-replacement.3859/
he said he bought this one - but it says unavailable currently. He said a low profile sub that wasn't taller than 4".
Amazon product ASIN B0037P3WICView: http://www.amazon.com/dp/B0037P3WIC/
I know someone else had some mdf rings or whatever like 3/4" added to the rear deck to get a little more clearance room in their trunk. I think they just measured what space they had under the speaker grill on the rear deck & were able to get a little thicker sub in that way as well.
Just saw this... Should for since the height is only 4.5". What do you think?
Kicker 40CWRT82 8" CompRT Car Subwoofer - Each (Black) Amazon product ASIN B00BUVRIY4View: https://www.amazon.com/dp/B00BUVRIY4/ref=cm_sw_r_other_awd_cLykxb3W3J22B
I would think it'd be ok, but I don't have one to measure how much room there is without adding a spacer/ring. I'm sure it could be made to work even if you had to add a small spacer.
I added an amp and a 12" sub. Factory speakers for mid and treble is great! Unless you are an audio snob ;)
he doesn't want a box though
There are options out there to build a sub over the wheel well. Check out JL Audio's stealth box. Mine is a basic box that tucks in the corner. I can take it out whenever I need more room by simply unplugging the speaker wire. It was much less expensive than the stealth.
I was running into a similar problem...wanted more bass but not the trunk rattling obnoxious kind. I went with a powered hideaway sub that fits under my driver's seat. (Sound Ordnance B-8PTD Powered Hideaway Subwoofer) It was around a $150 from Crutchfield and it was exactly what I was looking for. It adds really good depth and bass to the sound and there is an adjustment knob that mounts easily inside the coin tray to the left of the steering wheel.
