Nice write up, but this DIY uses the OEM fuel filter. The DW65C comes with its own fuel filter, but it cannot just be placed on the plastic that has the OEM fuel filter on it. I would like to use the fuel filter provided by the DW, but that means that the plastic on the bottom that holds the pump in place will not be there. Can anyone tell me what to do. I was Thinking of just using the oem Fuel Filter that's already attached to the plastic that goes on the bottom of the DW fuel pump. Honestly, I want to use their Fuel Filter. So If I use their fuel filter, and not used the plastic fitting on the bottom of the fuel pump, will this be a problem? Is it going to make the fuel pump move around since it would not be clipped on the bottom of the pump if I used the provided fuel filter.
I am installing a KW supercharger so this is one of the things that I also need to replace along with the 1000cc Injectors provided with the KW SC kit.
Can someone please answer my questions regarding the fuel filter?" I want to used a brand new fuel filter provided with the dW65c fuel pump, but it seems impossible because you cant attach it to the plastic bracket what is located on the bottom. I am confused as to why DW would even send a fuel filter that doesn't have the plastic bracket that has to be attached to do bottom of the pump. Very strange. I haven't tried to contact the DW company yet, I was hoping someone here would have an answer but now but it looks like people are just using the old OEM fuel filter since its attached/glued to the bottom plastic bracket.
Webby, any thoughts on this?
