JonnyRotten
Are you looking for new lugs for your stock wheels @cpj762x51?2014 Si Coupe. 1.25 or 1.5?
Yeah man. Just picked these up on eBay. Nothing fancy.Are you looking for new lugs for your stock wheels @cpj762x51?
12x1.5 is the thread pitch for the lug nut from the factory. You need "tuner" tapered lug nuts for aftermarket wheels.curious, 1.5 vs 1.25? i have a 14 lx sedan, i just bought the rota torque but dont want the extended lug nut look... unless the design calls for it?![]()
View attachment 53390 Mugen Heptagon lugnuts in black
Aftermarket wheels use the 60* so you are good.hey guys sorry about the necro bump but I have a question, I bought muteki SR48 nuts wich have a 60 degrees seat so I need conversion washers right ? or is it only when you run stock wheels ? I have aftermarket wheels , thanks !! edit : posted this in the wrong thread sorry !!!
What wheels do you have? Most aftermarket wheels use 60 degree lugs, but there are some that use acorn.hey guys sorry about the necro bump but I have a question, I bought muteki SR48 nuts wich have a 60 degrees seat so I need conversion washers right ? or is it only when you run stock wheels ? I have aftermarket wheels , thanks !! edit : posted this in the wrong thread sorry !!!
