What do you want to know? I am seeing him tonight. Car will be hitting autotrader.com soon from what I know.
Yea, I'll probably put it up on autotrader, as it doesn't seem like anyone in the local friend-base is showing enough interest.
Details:
07 Si, 2dr, Nighthawk Black
135k miles (supercharged for 71k miles)
The good:
New All Season tires
Freshly rebuilt trans (with OEM gears/bearings/synchros)
New ClutchMasters FX300 clutch
New front rotors and pads
Oil used: Amsoil 0w-30 and 5w-30 at OEM recommended intervals.
The bad:
Substantial "cancer" spots on the roof
May need a VTC actuator
Was put on frame straightener several years ago, due to highsiding the passenger side of the vehicle on a concrete light post base @ ~5mph. (The lightpost's bulb was out, and the car's A pillar blocked my view of said light post.) Knock on wood, never had an issue getting it aligned to desired specs.
Aftermarket windshield (OEM cracked one winter. NOT related to an accident.)
Needs new battery (still starts the car, but it is definitely weak.)
I'd like to see $4500 for the car. (If/when it is listed on AutoTrader, I'll likely list it for $5k, simply due to the STOOPID level of mark-up in the used market ATM.)
