- 24,277
Here are your Oct 2016 ROTM submissions. Best of luck to everyone this month.
[USERGROUP=10]@Registered 31+[/USERGROUP] please take a moment to vote. Thanks much
1) @xXFlash21Xx
Exterior -
5D High Gloss Carbon Fiber wrap on the hood
Roof painted gloss black
Rear window spoiler
Mugen rep window visors
Mugen spoiler
Eagle Eye tail lights
8k Hid lows
Yellow overlay fogs
JDM red emblems
White overlays on the "SI"
Interior -
6" bubble shifter
Silver on doors and around shifter wrapped in Carbon fiber
Yospeed cup holder cover
Red less under dash
10" JL audio sub with Kicker amp
Under hood/Suspension/Wheels -
DC Sports SRI
Muffler Delete
Ksport Pro Coilovers
XXR 527 18x8.75 on Nankang Noble Sport
2) @TeufNeph
2013 Honda Civic SI Mod List Engine:
K24Z7
PRL RBC Intake Manifold powder coated Hammered Blue
Valve Cover Powder Coated Hammered Blue
ZDX Throttle Body w/spacer ported to 72mm RDX 510cc injectors
Killerglass upper radiator hose with Blue LEDs
PRL Battery relocation kit
FKX Front Strut Bar
PRL Cold Air Intake powder coated Blue W/ K&N air filter
Full-Race Catted Downpipe, ceramicoated to 2000 deg
Full-Race 3" Header, Downpipe, Exhaust
PassWord JDM Blue fender washers
PassWord JDM Carbon Fiber fuse box cover
PassWord JDM Carbon Fiber ECU cover
PassWord JDM Carbon Fiber alternator cover
HasPort Dog bone,trans, Engine Mounts
K-tuned Blue Fuel Rail W/fuel gauge,
K-tuned Blue oil dip stick,
K-tuned Blue Oil cap,
Axion Ind. Oil catch can powder coated Blue
misc, blue LED lighting
HybridRacing Shift Bushings
Exterior:
Konig Illusion Blue wheels
Drag extended lugnuts
Custom Carbon Kevlar Mirror replacement housing shells
Carbon Kevlar door handle scratch guards
Seibon Carbon Fiber Hood
VIS Racing Carbon Fiber Trunk
5D Carbon Fiber Roof Wrap
JDM Red H emblem front,Rear
BaysonR front lip Paint Matched
PassWord JDM Carbon Fiber 3 piece front splitter
Color matched front and rear chrome,
Yellow fog light overlays
Mugen rep Rain guards
Mugen rep side skirts
PassWord JDM Carbon Fiber Side Splitters
HIN Whale Tail
20% Tint all the way around
5% 9" Strip front window
rear reflectors have been modifyed to rear tail lights and brake light combo
Interior:
Aries 3D all weather floor mats
Interior trim pieces are color matched to the car Dyno Blue Pearl ( Air vent rings, Parking Brake Handle, Shift Bezel Ring, Door Trim
Cf-Spec Carbon Fiber Window Switch Covers
Buddy Club short shifter
JDM Red Hazzard button with Bio-Hazzard emblem
Hybridracing cable bushings,
Hybridracing shift bushings,
CamArt Honda Vtec shift knob
Underdash, under seat, and door LED'S
NRG Hub adaptor
NRG Carbon fiber quick release
NRG Carbon fiber steering wheel
NRG Bucket racing seats w/ custom Civic SI seat rails/ with lighting door activated
NRG Four point harness
NRG harness bar
Audio:
Kenwood excelon 891HD /using stock microphone, also pulls and clears DTC's through stereo, also can view 5 gauges at a time I.E Air Fuel Ratio,Vacume,timeing advance, exhaust temps, Manifold temps,......
Rockford Fosgate 6 1/2 door and rear deck speakers
Rockford Fosgate 1" tweeters (replaced factory Speakers NVX MVPA4 Micro-V Series 400W RMS 4-Channel Bridgeable Micro Class D for components
Rockford Fosgate P3 12' ( currently in a sealed box) With a JBL GTO751 750W RMS
Suspension:
Godspeed Mono-Max Coilovers
Skunk2 rear Camber Arms
FKX Racing trunk cross brace 22mm Progress rear sway bar/w Moog adjustable endlinks, Moog bolt brackets
3) @Arm0ged0n
My Build Thread:
http://9thcivic.com/forum/threads/arm0ged0ns-2012-honda-civic-sedan-thread.4762/
2012 Honda Civic SI Sedan Alabaster Gray:
Engine:
o Sponsorship: Injen Cold Air Intake
o Sponsorship: Invidia Q300 Full Cat Back system
o RV6 2012+ Civic Si Bellmouth Downpipe
o K-tuned Red Dip Stick
o PasswordJDM Red Valve Cover Washers
o Skunk2 Fender Washers
o PasswordJDM Fender Washers
o PasswordJDM Yellow Oil Cap
o 8th gen RBC intake manifold, match ported to a stage 3, and polished (Painted red)
o PasswordJDM Kevlar RBC cover
o PasswordJDM Kevlar ECU Cover
o PasswordJDM Kevlar Fuse Box Cove
o PasswordJDM Kevlar Pulley Cover
o PasswordJDM Kevlar cooling plate
o PasswordJDM Kevlar Battery Cover
o 8th gen Throttle Body match ported and polished
o 8th gen fuel injectors
o Zerg Industries TB Spacer
o K-tuned Fuel Rail & Center Mount Gauge kit
o Spoon Reservoir Covers
o Hydro Dipped Spark Plug Cover (Red Skulls)
o Powder Coated Valve Cover in Blue (Glossy)
o Painted Motor mount in Red
o Red LED lights in Engine Bay
o HPS silicone radiator hose
o FKX Racing Front Strut Tower Bar
Stance:
o Enkei RPF1's 18 x 8.5 +30 Offset wheels
o Powder Coated (Blue Metallic) by Sponsorship : RJ Coatings
o Enkei RPF1's carbon fiber center caps
o Toyo Tires Extensa HP 215-35-18 performance tires
o Zerg Industries Chrome Open Ended Lug Nuts with removable center caps.
o R1 Concepts Front drilled and slotted rotors
o R1 Concepts Back drilled and slotted rotors
o Red Tire Stem Caps
o Airlift Bags with V2 Management (Sponsored by Airlift)
o Eibach 24mm Adjustable Front Sway Bar
o Eibach 19mm Adjustable Rear Sway Bar
o SPC Rear Camber Kit
o Red Painted Calipers
o Mooge performance end links
Exterior:
o 2012 Type R Bumper with Js Racing Lip (Painted and molded by Sponsor Idesigns)
o Mugen Grill with Mugen Badge
o Carbon Fiber Fenders
o SD Garageworks Retrofit
o Morimoto Mini H1 bi xenon projector retrofit
o Blacked out housing
o Switchback XSB Led Strips inserted in a silicone flex tube
o 10W RGB color changing demon eyes with Bluetooth controller for Android.
o Amber Removed
o Morimoto 4300k H1 Bulb
o Morimoto 9006 Relay Harness
o Morimoto Ballasts for Headlights
o OEM FD2 Honda Type R side marker with sockets and LED bulbs
o Honda OEM Red JDM Emblems
o Windows Tint
o Modulo with OEM painted Side Skirts
o OEM HFP Rear Lip Kit
o MGN Design Carbon Fiber Hood by Sponsorship: AdvanCarbon
o Custom License Plates
o Switch back LED Front Turn Signal Lights (Yellow and White)
o OEM Honda Mugen Style Window Visors
o Zerg Rear Window Visor
o Reverse LED Lights
o Eagle Eye Tail lights with LED strips
o License Plate LED lights
o NRG Chrome Tow Hook
o Trunk Swap for 9th gen EX
o OEM Honda EX Wing
Interior:
o 2014 Honda Civic SI back Seats (Black and Red)
o Type R Style racing seats (Cypher)
o Cypher Auto 5 Point Harness
o Charcoal Gray Suede on door panels (Sponsor Sweidit)
o Charcoal Gray Suede on Center Stack Cluster Hood (Sponsor Sweidit)
o Carbon fiber wrapped steering wheel
o Carbon fiber wrapped Hand Brake
o Carbon Fiber wrapped Stick Shift Center Console
o OEM HFP Red Mats
o Ambient Lighting Kit (Amber Color)
o Mugen Carbon Fiber (Red Stripe) Shift Knob
o CT-Engineering Short Shifter
o Yospeed Door Sills
o LED Map Lights
o JDM Red Hazard Switch
o Performance Ride/Proride Recaro Baby Seat
o Yospeed Cup Holder Covers
o Yospeed Dead Pedal
o Wood Trunk Set up by Fender Defender
o Airlift 4 gallon tank with Dual VIAIR 444cc Compressor.
ECU:
best of luck to everyone this month & thanks for voting
1) @xXFlash21Xx
Exterior -
Rear window spoiler
Mugen spoiler
8k Hid lows
Yellow overlay fogs
JDM red emblems
Interior -
6" bubble shifter
Red less under dash
DC Sports SRI
Muffler Delete
2) @TeufNeph
K24Z7
FKX Front Strut Bar
Exterior:
HIN Whale Tail
Interior:
NRG Hub adaptor
NRG harness bar
Audio:
Suspension:
3) @Arm0ged0n
My Build Thread:
Engine:
Stance:
Exterior:
o Amber Removed
o Windows Tint
o OEM Honda EX Wing
Interior:
o OEM HFP Red Mats
o LED Map Lights
ECU:
- Flash Pro
- Tuned by VitViper pushing 239 WHP and 200 torque
I thought the same thing...
