Worlds Smallest V12 Engine!!!
lol more time to play?
1220hrs of work... but he was able to achieve that :coffee:
My friend is building an evo motor thats about 10 times smaller than that. fully functional w/ crank, cams, valves etc and all the correct ports. around the size of my thumb. I'll get him to post pics some time..
love to see it
Wont threadjack too much. I'll talk to him and see how much I can share in another thread.
Here's the cylinder head. Designed on a computer, and 3d printed.
Hard to see the detail in white:
0.01mm resolution
Scale:
Calipers:
man that's small. So he's essentially using a 3d printer to make a mock evo?
only for the head. he's machined the rest.
Block:
center lock spindles w/threads (messed up)
"I had to grind a carbide tool to a perfect razor sharp point to cut the threads since they are only .0025" (.01mm) deep. The thread pitch is .2mm on a diameter of .080" (2.03mm)."
It's essentially a tube chassis DTM car ( whole chassis will be hand made from brass ( was done once, then changed, currently built w/ plastic until everything is done). Will have double A-arm suspension etc
/thread jack - sorry
That is insane!
