- 56,878
- 24,199
So you could run the “reflash/carb compliant” if you had the carb hondata unit.these are what show up.
i dont have any. i guess a custom tune map would be best?So you could run the “reflash/carb compliant” if you had the carb hondata unit.
You said you wanted to buy a carb unit? The carb maps would be what you could use.i dont have any. i guess a custom tune map would be best?
i asked about it because it was cheaper.You said you wanted to buy a carb unit? The carb maps would be what you could use.
