UPDATE:
Hey everyone, I finally have some unfortunate news regarding the car after nearly two months of back-and-forth with the old shop. Where do I start?
Let's start with the shop I was doing work for. After the constant back-and-forth regarding them trying to get my car, I found out the person who "owned" the shop no longer "works" for them. Sketchy, right? They didn't have a building to work on the car. They told me not to worry and they will find a tow company to tow my car from State College, PA to Philadelphia, PA and he would work on it in his garage.
After weeks and weeks of beating me around the bush, I had no choice but to send the car to the Honda Dealer. Need my car back by August 29th.
After a full day of looking over the car at the dealer, Honda found the problem.
The speed sensor on the transmission was melted, causing the car not to start. Once unplugged, the car started and idled with no problems. So that was the electrical issue.
As far as the mechanical issue, this is where things get interesting.
When they cracked open the drain plug to my transmission, not a drop of fluid came out. It was bone dry, even to the touch. This cause the transmission to overheat and seize, as well as melt the speed sensor. Unfortunately, I need to replace the entire transmission.
What's interesting is this - when the previous shop installed my clutch, they refilled the transmission up with motor oil, not transmission oil. How would that completely evaporate within a timeframe of 3 hours on the road? Hmm...oh yeah, the car was leaking oil the entire time in my garage from the transmission. I'm led to believe the transmission was never installed properly after the clutch was installed.
At the end of the day, the transmission speed sensor needs to be replaced, as well as my transmission. The dealer informed there is a possibility my new clutch and lightweight flywheel also needs to be replaced, but they won't know until they officially take apart the transmission to replace it. In my head, that's very unlikely.
So, there's the update. We know what's wrong...but now what?
If the entire clutch, flywheel, and transmission need replacing, I'm looking at nearly $4,000. If just the transmission, $2,700. What do I do regarding the older shop? Bite the bullet, take them to small claims court? Any legal advice here?
