Tim Abadie
One more question, would it be best to put the RMM in before or after DP/exhaust or does it not matter?
I did use a o2 socket. I ended up just buying a denso o2 sensor and leaving the oem one in the oem down pipe.Are you using an o2 socket? If the downpipe is off the car you can hit it with an impact.
Great dyi! It really provided lots of help and detail. After going through your guide i had a better understanding as to what i needed to do to easily instal my k-tuned downpipe. Thanks again!This @Full-Race DIY is finished!!! Sorry it took so long to get to.
I still can't believe it's been 5 years since I uploaded these videos!![]()
Too bad my car is a 2012...
Just installed my downpipe on new years eve this DYI hella helped me out took about 8 hrs had to keep coming out for tools lol got the motor mount in aswell .I get some weird idling tho when in neutral if any 1 gots any info on that fix .Thanks for the install guide .
your car is not going to run properly without getting hondata flashpro and a tune on aftermarket downpipes. This is quoted from the diy aboveLesson learned: To run this downpipe and exhaust, you need FlashPro and a proper tune! If you do not get a proper tune, you may throw a CEL and/or have horrible rasp depending on what mods you have installed.
