- 56,836
- 24,189
I know some 8th gen si owners set theirs between 8600-9000 for fuel cut without issue. Others upgraded springs to go 9500 fuel cut.
________________I believe the factory fuel cut is at 7,200? @webby
I normally shift a little early around 7,200-7,500
______________Yeah, 7200 is supposedly oem limit without flashpro/ktuner.
Bruce, bobistheoilguy has threads where they’ve said wix and amsoil had some identical metal stamping even inside. They claimed Donaldson was making the synthetic media for amsoil, but the casing was from wix assembly.
On the Bosch, f you carefully at their claim of "99%" efficiency (it's on the box) you'll notice there's no micron level attached to it. So the 99% is meaningless.
On the contrary, Amsoil uses the 15 micron level... which is a very high bar for a full flow filter.
______________mobil 1 extended m1-110 filter
Keeps oil cleaner, longer – 99%+ efficiency*
• Synthetic blend media keeps oil cleaner and holds more dirt†
*Efficiency rating based on removing particles greater than 30 microns
__________the fram ultra synthetic 20k mile
XG7317
2-ply synthetic, metal-screen-reinforced media provides 99%+ filtration efficiency.*
*FRAM Group testing of average filter efficiency of PH8A, 3387A and 4967 or equivalent FRAM TG or EG models under ISO 4548-12 for particles greater than 20 microns.
their tough guard filter also claims 20 microns on the same iso test. 99%+. The standard filter is saying 95% at 20 micron.
at least the ultra construction looks a lot better. I know I've seen videos from the early 2000's and the fram filters looked pretty bad on the inside with a lot of cardboard material. Looks like the 2 lower models still use some form of cardboard material. The ultra filter for the si is showing $9.42 on walmart's site for me currently.FRAM has had such a horrible reputation. This is damage control.
View: https://www.youtube.com/watch?v=Y544o-mw2wc
Right off the show room floor it is not worth pushing the fuel cut to 8k you will lose power at 7000 RPMs. I am sure I can find a video of someone with stock internals. I am sure most people do E-tuning so it makes it hard to find some dyno results some time.Well its good to know that the Honda engine exceeds specs even, I would like to see a Dyno run going to 8,000. Post up video, someone must have done this. What makes honda engines hold up at that rpm? I can't even find out what the engine block is made out of or other internal parts-seems to be hidden.![]()
