Mike's boosted build
Wowza. How u running it? Along the same path as the stock line?
That's the plan right now lol. I'll see once I start running it tomorrow. I got the fuel rail on just got to run the regulator and lines back.
That’s what I ran a -8 to a surge tank 3 pumps inside it and a -6 return
What phone you running Mike? I see weird buttons at the bottom. Like purple.
Just got into WOT to redline pulls. I got to say I am extremely impressed with what just E85 will do. I am also adding a few LBS of boost.
I am finally finished with my base tune. I was working on getting the AEM boost controller to work and eventually took it out and changed my spring's for the 2nd time today. Now we can start moving forward on making more boost currently now making 16.8 lbs.
How much do you plan on making?
your stock internals right?
I am going to take it out as far as I can. I don't know what numbers I am currently making at the moment but from just running 12.2 psi the car was running strong and pulling really hard.
I am currently on stock motor and have plenty of room to push it with the factory internals. But for the transmission I am currently pushing it over the limits lol. I spent most of monday taking my old K24Z7 apart and just admiring the old motor and getting ready for a rebuild.
Isn’t there a giant hole in the block?
Kinda dumb question, but how old would you say is too old to boost an engine? >.>
That motor has a good size hole in the bottom of the block and oil pump from the rod. Not planning on using that one we were just taking it apart for fun so when we I get a new block I have an idea what to do as a rebuild stand point.
