A new member here, hello everyone!
Engine & ECU:-Cobb AccessPort
-MXP Cat-Back Exhaus
-AMS 900x Rotated Location V-Band Turbo Kit
-Tial 44mm EWG Upgrade (Blue)
-Tial Q BOV (Blue)
-AMS FMIC
-AMS FMIC Optional Crash Beam
-Cosworth Subaru High Volume Inlet Manifold (2004-2009 STI)
-Crawford Air-Oil Separator for FMIC fitment - Subaru STi 2008+
-Crawford High Performance Water Tank
-Koyo Aluminum Racing Radiator - Subaru STi 2008+
-Samco Radiator Hose Kit - Black - Subaru STi 2008+
-NGK Iridium Spark Plugs (One Step Colder) / Heat Range 7 (LFR7AIX) -Aeromotive 340LPH In-Tank Fuel Pump
-Walbro 255lph Fuel Pump
-DW 1300CC Fuel Injectors - Subaru STi 2008+
-Grimmspeed EBCS
-Gates Full Timing Kit-ARP Headstuds for Subaru WRX STi EJ257-Subaru OEM Complete Engine Gasket Set
Drivetrain:
-ACT XTSS (full-face) Clutch
-ACT Streetlite Flywheel
-Kartboy Short Throw Shifter
-Kartboy Front Bushing
-Kartboy Rear Bushing
Suspension & Brakes:
-AST 4100 monotube coilovers
-Vorshlag front camber plates -Cusco Rear lateral links (08+ STi)
-Whiteline 24mm front sway bar (heavy duty blade) - BSF39XZ -Whiteline 22mm rear sway bar (heavy duty blade) - BSR49XZ
-Kartboy Front Endlinks
-Kartbuy Rear Endlinks -Whiteline Front lower control arm rear brace - KSB723
-Whiteline Front lower control arm rear support plates - KBR14
-GT-Spec 08+ STI Lightweight Rear Bumper Beam Replacement Brace
-Whiteline Street anti lift kit - KCA334 -Whiteline 08+ STi Positive Shift Kit - KDT901
-Whiteline Steering Rack Bushing kit - KSR207
-Whiteline 08+STi Positive Traction Kit - KDT902
-Whiteline Front inner control arm bushing kit - W0507
-Whiteline Rear differential mount inserts - KDT903
-Whiteline Rear shock lower bushing kit - W0505 -Whiteline Rear trailing arm bushing kit - W0568
-Whiteline Rear lateral/toe arm (turnbuckle adjustable) - KTA125
-Whiteline Rear subframe positive traction kit - KDT907
-Whiteline Rear differential positive power kit - rear - KDT906
-Whiteline Roll center adjusters kit - KCA313
Exterior:
-19x10" +35 Advan RG-D Wheels (Gold)
-Yokohama Advan Neova AD08 (265/30/19)
-BlackTop Aero VR-Style CF Front Lip
-JDM R205 STi Black Side Badge
-Red taillight overlays by Underground Graphics
-BlackMax tint by Executive motorsports (35% sides/20% rear window)
-Clear Bra by Executive motorsports (only on headlights)
-Perrin Shorty 2" antenna
-JDM rain visors
Accessories & Interior Styling:
-Prova SI-Drive Dial Subaru Legacy GT 2010 / STI 2008-2011
-ARC titanium shift knob
-JPM Coatchworks short shifter shift boot in black alcantara with diamond red stitching
-JPM Coatchworks brake boot in black alcantara with diamond red stitching
-DAMD "D-Shape" flat-bottom steering wheel, black w/ red stitching
-JCS Pods 60mm Triple A-Pillar Gauge Pod - Wrapped By JPM CoathWorks In Black Alcantara With Bright Red Stitching
-JPM CoatchWorks Passenger A-Pillar Wrapped In Black Alcantara
-DefiLink control unit II
-DefiLink BF Imperial boost gauge
-DefiLink BF Imperial egt gauge
-DefiLink BF Imperial oil pressure gauge
-SMY ClusterMaker Dual Gauge Pod Cluster
-Innovate Motorsports DB-red wideband
-HKS LCD Turbo Timer (Type 0)
-HKS 08+ STi Turbo Timer Harness
-Custom Auto Shade perfect fit sun shade
ICE:
-Pioneer AVIC Z120BT Head Unit -Pioneer ND-MDT10 MSN Direct Tuner
-Pioneer CD-IU50V USB Interface Cable for iPod/iPhone
-Pioneer GEX-P920XM XM Satellite Tuner -Kenwood CMOS-200 Rear View Camera-JDM STi A/V Panel -SVXdc Aftermarket Headunit 20-pin wiring harness (W/O CAN Wires)
-SVXdc Parking Brake Bypass for Pioneer Avic Z120BT RCA Harness
-Metra Axxess ASWC Universal Steering Wheel Control Interface -JL Audio HD900/5 Amplifier -Focal 165K2P front 2-way component speakers
-Focal 165CV1 rear co-axial speakers
-IA Performance Complete Speaker Adapter Kit - Subaru 08+ [IAP-COMPvb] -Audio Integrations 10" perfect fit sub enclosure -JL Audio 10W3v3-Valentine One Radar Detector
-Valentine One BlendMount Kit
-Valentine One In-Line Hard Wire Kit
-JL Audio 2 Gauge Amp Install Kit
-JL Audio 12 Gauge Speaker Cable
-JL Audio Blue RCA's
Future Plans:
The car will be built through the next 2 years as a fast reliable DD with plenty of power and suspension mods to participate in track days, after that it will be shipped to Saudi Arabia (I'll be working there starting 2012) and will participate in shows and track days there, and will be street driven to meets and such to represent what subies are capable of since there aren't many STi's over there, hopefully one day I can hang out with the guys from Bahrain too since it's like 30 minutes away from my place.
Planned Build (EVOLVING):
-AMS Small Battery Kit -Built Motor (TopSpeed RR1/Race Head Port)-KillerB oil pan
-KillerB oil pickup tube
-Aquamist HSF-6 methanol injection system
-Howerton Engineering enclosed tanks and pump setup -AMR UEL Header
and much more...
Note:
Everything was purchased and ready to go on the car, but a change in plan made me part out and go a different route
That GTR looks like it wanted to eat the Suby....
That's the point of the picture :D
Def was the best one....alot of great peeps were there.
Agreed about the great peeps, it was great meeting you all :)
My tongue :D :D :D :D :D
YUS! :D
wow. sti hatch = <3
Thanks you, I absolutely loved them both :D one of the best cars for the money I would say!
Mod list? you may need a few posts because of character limit..
Posted, it's not that long :giggle:
:ohnoes: is this the new cool smiley :D?
I think he sleeps in your bed :corngrin:
Hi ASHRAF, can you tell me how do you connect your Axxess Steering Wheel Control Interface. I did it but it doesn't works. Which wires did you connect and which connector pin do you use ?
Thanks
White STi. drool:
Welcome to the site!
ASHRAF was at Downtown Disney with me tonight...so he's on vacation with his family. I'll try and direct him here :)
Thanks
Hello Alain,
I had the PAC-SWI-PS installed and it was quite laggy, so I had my friend swap it out for the Metra and it was 10 times better
he did have an issue with the install, contacted David Carter (SVXdc, Audio guru on NASIOC), and he helped him with the install, so that is the guy to ask if you are having trouble
this is his guide, it may be helpful
http://ae64.com/20-pin-pinout.htm
*check "I" under notes
sorry for replying late, I'm just away from home fro a family vacation, if that is not helpful, let me know and I'll call my installer :)
-AJ
