Help with retaining factory backup camera with aftermarket headunit. 2014 Civic Si
jqqzxv
Active Member
5
2
Hi there, I recently got a new headunit for my Civic, I used the PAC RP4-HD11 to retain steering wheel controls. The problem is the 7 pin connector they mention in the directions to tap into for the backup camera isn't there so I'm wondering if anyone knows what connector or pins contain the backup camera wiring. Thank you in advance.
Appears to be the 24 pin connector in the 2014 civic.
J3 is video ground
J4 rearview camera ground
J15 camera signal
J16 camera power
J17 control signal for camera
Appears to be j15 on the 2014 civic
You are a life saver, Thank you so much!
J3 is video ground
J15 camera signal
J16 camera power
I'm a little confused as to how I would wire this as the instructions shows wiring for Video- Video+ Camera- and Camera+
I would assume they mean ground for the (-) and signal or power is (+)?
I see j2 says shield for 3,4,15,16. Maybe those are the 4 you need to use?
Maybe it’s
J3 video -
J4 camera -
J15 video +
J16 camera +
? These are guesses, and without sitting there with a multi meter testing, I’m not sure. I don’t have a 2014 to test this theory out.
Maybe it’s
J3 video -
J4 camera -
J15 video +
J16 camera +
I got it figured out, it ended up being the exact order you put. Everything works perfect now, thanks again and have a Happy Thanksgiving!
