team3d
harmonic balancer is only found mostly on V8 engine, especially cross plane v8, why ? Because its low tech engine with very long crank that can’t be blue print & balance perfectly. so they added an external balancer as a band aid fix to cancel out the vibrations…
honda inline 4 engines DO NOT use harmonic balancer (I should say all inline 4 engine), that’s a fact, we use standard crank pulley for our belt driven Accessories to power the water pump, alternator, air con, power steering (9th gen use electric power steering) .
do inline 4 engine have vibrations? Yes, k-series def have internal engine vibrations, and we have 2 types of vibrations, a primary & secondary, not going into details but if your interested, you can purchase the research paper through SAE if your interested.
to cancel out primary vibration, you add counter weight on the crank, that’s it, it’s that simple & not so scary, because all honda cranks have counter weight, just make sure when you build your motor, spend the money to have the crank (stock or aftermarket ) balance it before install.
