If you have push button start-
1. Close the driver’s door, and leave it closed until the procedure is complete.
2. Turn ignition to LOCK (0), or press the engine start/stop button to select the OFF mode.
3. Press and hold the tilt switch, and turn ignition to ON (II), or press the engine start/stop button to select the ON mode.
4. Release the tilt switch, and turn ignition to LOCK (0), or press the engine start/stop button to select the OFF mode.
5. Repeat steps 3 and 4 four times. Note: Each step must be performed within 5 seconds of each other.
6. Press and hold the moonroof open switch for 3 additional seconds after the moonroof is fully opened.
7. Press and hold the moonroof close switch for 3 additional seconds after the moonroof is fully closed (tilted).
8. Check if the AUTO OPEN and AUTO CLOSE function still work. If they still work, the AUTO functions have not been cleared, go back to step 1. If AUTO functions have been cleared, go to step 7.
9. Press and hold the moonroof close switch until the moonroof is titled fully opened.
10. Confirm that the moonroof control unit is reset by using the moonroof AUTO OPEN and AUTO CLOSE feature.
