Honda-Fan
WHATFinally got a computer working in the shop today. Made the background look like where I wish I was.
Optiplex.
WHY WOULD YOU HOOK ONE OF THOSE UP
Optiplex.
strip lights under the little roof, or uplights from the well so it looks like its glowing all nightwhere would you put them, or what kind?
Are there water lines exposed under the house? It may be there purely to keep the water lines from freezing. Nomar had a similar situation on his house.Afternoon.
So all winter I've been curious as to how my hydro bill got higher even though we never used our baseboard heaters and only used the wood stove. Thought it was because the wife and inlaw were doing laundry more often and we were cooking inside more often. Then I went to get my exhaust from under the house and it was like a sauna under it because theres a baseboard heater on. I'm not sure if it's even necessary to be on. At least not any more. Didn't have time to see if there was a switch on it.
But problem solved. Paid like and extra $60 every two months for one baseboard heater.
Yes but i feel like it doesnt need to be as warm as it is. its all spray foam insulated as well. it got to -10c here for a week.other than that it rarely gets below freezing other than at night.Are there water lines exposed under the house? It may be there purely to keep the water lines from freezing. Nomar had a similar situation on his house.
So as long as it doesn’t get cold enough to have pipes freeze under the house. I don’t know if that unit you have can be adjusted with a thermostat to say 40-45 degrees (4-7 degrees C)?Yes but i feel like it doesnt need to be as warm as it is. its all spray foam insulated as well. it got to -10c here for a week.other than that it rarely gets below freezing other than at night.
What happened to the original camshaft, or what vehicle is that from?Camshaft day.
I found a knob. I set it much lower. I'll check it in the morning. Doesn't have any measurements on it.So as long as it doesn’t get cold enough to have pipes freeze under the house. I don’t know if that unit you have can be adjusted with a thermostat to say 40-45 degrees (4-7 degrees C)?
Usual hemi things.What happened to the original camshaft, or what vehicle is that from?
Feel like I'd rather have that than the taco but a truck bed is more useful.At the local Toyota dealer getting a free service(oil, filter, tire rotation, cabin filter) and also having them check the brakes since the shake a little.
No fun cars on the lot which is a shame, lol.
Forgot my Bluetooth headphone thingies. So can’t waste the hour wait watching YouTube.
This 4Runner is nice….cool/interesting color.
Somebody else saw a pattern I’ve been seeing. Airplane issues last week most stemming from United Airlines operations out of SFO. Recent issues coming from 20-30 year old aircraft being associated with Boeing’s manufacturing woes.
https://www.nbcbayarea.com/news/local/united-airlines-san-francisco-medford-oregon-panel/3483139/
yikes, that cam does look rough. You could get a cheap thermometer and mount it somewhere under the house. That way you could see how the temps look depending on how cold it gets.
