If I had the information, I'd likely save it in the event I decide to use it. If I had a link to the old AEM forums, I'd try and see what I could pull from the Web Archive but the closer you get to a complete link to the actual page you need, the better it works. However, if you're thinking of reverse engineering things to re-figure out how that was done, that is also possible but it would be of limited value since AEM has been bought up by Holley and they discontinued any support for old AEM EMS units.
Yea I was thinking web archive, but didn’t look to see how much of their forum is archived.
after digging for a bit, I was able to get to the index without inputting a name/pw. Sadly it may take a lot of digging, unless you know where the post was, since searching the database doesn't work.
https://web.archive.org/web/20050712014538/http://forum.aempower.com/bbs/index.php
this takes you to the mitsubishi/3000gt section in 2005. No clue how old of a post or thread it was, but you could play with the date/year if needed.
https://web.archive.org/web/2005071...php?f=28&sid=325fab80159aebd3feeb237c1e3cdaa6
I am pretty sure it was after this point since I didn’t have an EMS until 2006/2007. I remember seeing it after I had joined the forums around that time. If I get some time, I’ll try and poke around for it; but, I think it is gone…unfortunately.
Any chance you found out about the aem post from a 3000gt/mitsu forum link? Any chance you made a post in either potential thread, or recall any usernames in either?
Other than my personal username (same as here), no. I can look on the 3/S forums for the information but I only remember seeing it on AEM forums.
Okay, I just didn’t know if maybe you saw a link about it on the 3/s and it took you to the aem forum. Just a thought I had.
