2012si2012
Hi all, i made a poste about how to change and install HiD kit 9006, but some of the pictures doesnt work. so i will post a new one rigth here in DIY.
sorry for the inconveniense.
sorry for the long picture post!
First you will need the tools!
Rachet+10mm bolt remover
Tierap(at least 4)
Philips screw driver( the star one)
electric tape ( if needed)
the kit you will need its 9006 single beam Hid Kit (in my case i put 10000k
View attachment 4274View attachment 4275
1- First find where are the holes
View attachment 4276View attachment 4277
2-Turn the plug to the left and remove it gently
3-Remove the light from the plug
View attachment 4278View attachment 4279
4-Assemble all the kit together
5-Remove the Bulb cover and insert inside the Headlight----BE CAREFULL TO NOT SCRTCH THE BULB----
View attachment 4282View attachment 4281View attachment 4284
6-Connect the power wire to the HiD plug power
7-tierap the ballast firmly to the frame
it can be many way to tierap the ballast in your car.***
8- Test your new kit!
View attachment 4287View attachment 4288
For the battery side... if you want more room to work, remove the bolt that retain your battery.
do the same thing for your other headlight!
Finaly ...ENJOY your work!!
sorry for the other post.
hope that will help it!
thank you.
Tierap(at least 4)
)View attachment 4274View attachment 4275
thank you.
