bigbossin
Hmm I'll probably should cut mineIt's good, no problems at all. I must say since this is the first time I've ever had a shifter, I had a couple of minutes to practice shifting before driving LOL.
Wait you got yours too? If you did, you definitely need to cut that piece out bro.Hmm I'll probably should cut mine
I have one for the 8th same design as this one only thing is reverse is iffy getting into sometimesWait you got yours too? If you did, you definitely need to cut that piece out bro.
Yea, that's because it's rubbing against that piece of plastic.I have one for the 8th same design as this one only thing is reverse is iffy getting into sometimes
Then all you have to do is pay Canada Post the taxes and it's all yours TeeEyeVany!
Yup I will have it apart in the morning once I'm off work and cut that sucker offYea, that's because it's rubbing against that piece of plastic.
And after you are done, you can thank me afterwardsYup I will have it apart in the morning once I'm off work and cut that sucker off
LOL No problem
It lengthens the bottom part of the shifter reducing how far the hand has to move for each gear. It's a really good addition.
Yea thatChanges the fulcrum which makes the bottom part move more when the top is moved, its science.
