JohnEnglish
- 5
My 2012 EX-L Coupe has the premium audio system. I'm looking to upgrade it in stages. I was going to start with the speakers first.
Since I have the premium audio system, the crossovers for the front woofers and tweeters are in the amp itself, correct? That means that if I'm installing 2 way component speakers up front, I wouldn't use the supplied crossovers until I replaced the factory amp? I would just wire the woofers and tweeters directly and then when I replace the factory amp I would use their crossovers and run the tweeters the that?
