igor gojkovic
Active Member
- 26
- 9
Hello guys, I have purchased some ShiftGlow 52mm Gauges. One is a water temp gauge while the other is a Boost gauge that I plan on connecting to the vacuum line for now and later to my KreftWerks supercharger that I will be getting.
I need help on wiring the water temp gauge and the boost gauge to the dash lights of the car. I want the lighting to turn on when the inter dash lights turn on and they also have a wire to dim when the headlights turn on and the dash lights dim at night. I don't know which are the wires that I need to connect my water temp and boost gauge to in order to get them to do this. Can someone please help me out so I can get this done correctly.
Question 1: How do I wire the water temp gauge and boost gauge to the interior dash lights and how where do I tap the dim wire to?
Question 2: Where exactly is the vacuum line located? I need to put a T fitting in it so the vacuum would show on the boost gauge.
So far, I have drilled two 52mm holes in the console tray and placed them there. Now I am ready to wire them to the dash lights but don't know how to. Please help.
