Back Up Light (Reverse Light)
/°xXx°\
2
I have been searching the forums and I haven't found any DIY threads/posts on replacing the back up light on the 2012 Civic Si. According to the 'Sylvania Lamp Replacement Guide' (https://www.sylvania.com/en-us/applications/automotive-lighting-systems/Pages/lrgmain.aspx), which is what I referenced to replace the dome, map, license plate and trunk/cargo lights with LEDs, the back up light (reverse) bulb is Part # 921. Has anyone replaced the back up lights? If so, is there a DIY I missed on the forums? Thanks.
Have you already attempted to use the instructions in your Owner's Manual?
Coupe:
Sedan:
My apologies, I should have checked the owners manual. :pat: It looks simple enough. Thanks for the snippets from the manual.
