team3d
Where are you at?
los angeles
Where are you at?
Oh I was just curious about fitment. Just seeing how much playing around you guys might have done.
Red powdercoated tsx calipers and brackets are like $150 for a set of fronts. Autoanything/jcwhitney/carid and such. They are definitely remans. Nowhere near as nice as any bbk you guys carry but for track guys a cheap effective upgrade. No idea on 9th gen fitment though.
I wish I had bbk budget. I got plain tsx reman calipers for $40/each but I know they fit 8th gen.
He hasn't been on in months. This will send him a notice you have a question.Came across this old thread. @team3d Do you have any information on 6 pot BBK's that will fit our 9th gen Si's (aside from Wilwood)? Looking for prices, fitment, and color options.
I was going to ask about that. I can't imagine they make a larger floating caliper than what is already on the 9th Si, and even if they did I don't see a slightly larger floating caliper providing much more braking capability. However, it did remind me that I saw a debadged Acura (guessing TSX) a couple days ago with proper 4 piston calipers upfront that appeared to have come from the factory. I'd be curious if they fit our 9th gens as they would be the next step up short of a BBK. They appeared to be on 300mm rotors.It's almost the same caliper thats already on the car though. The caliper part numbers are the same other than the revision number. The ears on the pads are different shapes. It's also the same caliper that is on the 04-08 TSX. Just good pads and fluid should be enough to get a lot more brake out of the car.
