corybgee
Thanks! Me too! Can't decide which I like better
They are project Kic lug nuts.Your car looked dope when it was white. Im not really feeling the pink wrap but if you like it thats what matters. I like how the rotors look tho and what kind of lugs are those on you rpf1 wheels?
Man I love how that looks in that engine bay! Would love to slap one on my 13 SI, is that one for the 8th gen civic? Do I have to buy a lot of parts in order to install it?
The coolant bypass you installed, can that be purchase in replacement of the adapter plate PRL sells when upgrading to an RBC/RRC manifoldView attachment 49143 View attachment 49146 View attachment 49145 View attachment 49146 View attachment 49147
Edit: Well this is a mess.... Guess I shouldn't try to post from an ipad..
Yes, the Manifold needs to be cut, but once done the PRL plate is not needed. That is part of the reason I got it, My PRL plate was leaking coolant.The coolant bypass you installed, can that be purchase in replacement of the adapter plate PRL sells when upgrading to an RBC/RRC manifold
Yea it seems as so that would be the better route, plus you can take full advantage of Thermal instake gasketYes, the Manifold needs to be cut, but once done the PRL plate is not needed. That is part of the reason I got it, My PRL plate was leaking coolant.
Great minds think alike. Idk if I know you but I just noticed you're in AZ which is where my car is and where I'm from.Yea it seems as so that would be the better route, plus you can take full advantage of Thermal instake gasket
I'm not sure if we've meet before. but back beginning of 2014 i started AZ9thGenSi which is a group that turned into a bunch of RA tards and is now called AZ9thGens. Other then that, im not sure if we've met. When will you be back state side?!Great minds think alike. Idk if I know you but I just noticed you're in AZ which is where my car is and where I'm from.
I am deployed for 2 more months, And then go back to Japan for about 2-3 years.. But ill be home visiting the family probably Dec or Jan. and other times randomly.I'm not sure if we've meet before. but back beginning of 2014 i started AZ9thGenSi which is a group that turned into a bunch of RA tards and is now called AZ9thGens. Other then that, im not sure if we've met. When will you be back state side?!
Car looked awesome pink... haha. Do you still have the TE's on there??
