driving voltage
nat3d
Wait, I don't drive a civic anymore....
VIP Member
3,335
1,566
Adams MA
Ford Focus ST
Hatch
hey guys i have a voltmeter and as im driving ive noticed that on ocasion rather than run at 14.3v my car has been running at 12.5v and when it first started it was only when i was on the gas it would drop to that but now it seems constant (as of my drive home) whats going on?
ADExternal
Lvl: 99 Modifier
1,917
1,535
Houston, Tx
Civic Ex
I got you @nat3d .
A car alternator needs to be putting out at least 13-14 volts (ideally between 13.8 and 14.2 volts) to effectively charge a 12 volt car battery. If the alternator is putting out too much voltage (15+ volts), it is likely your battery acid will boil over out of the battery. On the other hand, if its constantly at 14v than your battery isnt holding its charge or its losing charge somewhere in your system very fast.
As long as its between 13-14 volts, your alternator is working fine. So its just the battery at this point.
nat3d
VIP Member
3,335
1,566
Adams MA
Ford Focus ST
Hatch
I got you @nat3d .
its been sitting at 12.something though :/
Monk
2,196
SW Virginia
2012 Civic EX
Coupe FG3:ASM
i have a volt meter wired
If it isn't wired directly to the batt you're going to get a lower reading than what the batt is actually doing.
the insider
253
north of the 49th, south of the 401
civic si
sedan
The charging system on the newer Civics don't work like they have traditionally - there will be times when you are driving that the alternator will not be charging. The charging protocol has been changed to improve economy.
Chuckable
34
the insider is correct, at least for Si models. Others, I have no idea. Try turning on your headlights. Your voltage should increase. If not, I'd take it to the dealer.
