dpetro1
Great choice. I'm running the same size
Yea but i dont wana roll my. Fenders an what size tire would i get. Or should i go 18x8I have 18x8.5 +35 fenders are rolled and slight pulled due to rubbing sits very flush and no more rubbing after fender work
So do you think 18x8.5 +30 with 225/50/18 tire would good enough with no mods on fender or camberpeople doing fender mods or camber are maybe 2inches (or more) lower than stock.
I just installed a set 18x8.5 35 offset with the stock 225/40/18 and I rub on turns and big bumps, im at -1.3 camber in the rear and -0.8 in the front. Im getting my fenders rolled next week..
Thanks for the advice man appreciate itNO. It will rub. And 225/50 is the wrong tire size. 225/40 is what you want.
If he rubbed with a +35, the +30 will rub worse. The lower the number, the wheel moves towards the fender. The higher the number, the wheel moves towards the engine.
Get the +40 or +45 wheel you were looking at. If you want to be flush you will need the +35 and to run more neg camber than he was or do some fender work. You could also run the +40 and depending on tire, most likely not rub but also be pretty flush. +45 is stock offset so not flush but no rub and 0 camber needed.
