kseriescivic
- 96
Thanks man, I'm going ct-e instead so I'll need an intake eventually.Cars sweet dude! May I make a suggestion tho if you wanna go the kraftwerks rout maybe you should wait on the intake since the kraftwerks kit comes with its own special intake.
That's my 2¢
Good choiceThanks man, I'm going ct-e instead so I'll need an intake eventually.
I will upload it to vit when I get off at midnight (damn night shift) but hopefully I can do a couple more tonight, go to bed, wake up early and do a couple before work. I'm gonna try and be tuned in 2 weeks or less.I'll most likely go to the drag strip for wot pulls, if I can get an internet connection out there. If not, I've been searching for nice open roads far from anyone. At least with boost the pull is over fasterI have to admit the datalogs were a lot easier to do when he told me to stop at 5500rpm, with boost and going to 7500 it's not quite as easy to find a safe time and place to do the pulls. Hope after boost you have a good spot for that.
Webby do you know if the very first basmap would mess with my idle? I'm assuming since it was a map made from scratch it it would cause that. It only happened if I barely dabbed the throttle at idle.Coming along very nicely![]()
