Loppysaurusrex
- 65
And cheapest would be nice too
OhI am right around 230 at the wheels...which would be roughly 275 at the crank.
RBC, ZDX, PRL SRI, Full-Race DP and exhaust.What's your setup? RBC, e85?
Oh
What's Honda rate it at? The crank?
If so I meant 260 at the crank forget what I said
So... Vitviper tuneGenerally every manufacturer rates their cars at the crank. Unless you specifically see where it says wheel horsepower. 260 at the crank equates to about 221whp given about 15% parasitic loss though the drivetrain. So if you want 260 at the crank you could achieve that with quality full bolt ins and a good tune.
So... Vitviper tune
Exhaust, air intake, header, what else?
I also heard that stock air intakes provide more than enough air for the engine
Realistically, all you need is a 3" DP/exhaust, 3.5" intake, and a tune.
This and the Hasport rear motor mount. Extra power won't do you any good if you can't put it to the pavement effectively.
This is the truth. I ran auto x on the all seasons and they can't compete with a good 200 tread wear tire.On that note, get some summer/performance tires too!
Yea my front tires are still the same ones from the factory I think, I got the car used at 17k miles and it has 24.5 now :/On that note, get some summer/performance tires too!
