KennyGS
How may I help?
that auto still looks spiffy
hope you do a great DIY
would be clearly awesome especially if you had the time for the rear shade
I wonder why those words were filtered. They seem fine to me.
The shade is a really easy mod. The OEM Passat blind is 42 inches long. I used my Dremmel to cut 1 inch from each side and a round cutter and a metal ruler to finish the blind itseft. Then take the rear garnish and screw the blind. Since this is plastic, I used metal clips to give the screws something to hang on.I wonder why those words were filtered. They seem fine to me.
Any reason you didn't want to just do a dark tint?The shade is a really easy mod. The OEM Passat blind is 42 inches long. I used my Dremmel to cut 1 inch from each side and a round cutter and a metal ruler to finish the blind itseft. Then take the rear garnish and screw the blind. Since this is plastic, I used metal clips to give the screws something to hang on.
This is a $20 - $30 mod
that's what i ******* thought then i ******* saw the ******* guy come and ******* nothing ******* went. That's why i **** guess **** :/
kinda *** **** if you **** *****
nvm :/What?? I can't understand what you're saying Ali.
for some reason, this is a feature i always wanted, but I wanted a stick more. what is involved in adding this? do you just need the switch? or?
- Installed variable intermittent windshield wipers.
yeah just swap it with the accord stick and use an auto-dimmer type module for 12v A potentiometer essentiallyfor some reason, this is a feature i always wanted, but I wanted a stick more. what is involved in adding this? do you just need the switch? or?
Upgraded the grille base keeping the stock grille and upgreded the low beam to Volt HID 4300K
View attachment 14661View attachment 14660
