Octane 87 and the SI
Discussion in 'Civic Si Models' started by RightNow800, Jan 22, 2017.
  1. RightNow800
    RightNow800 Member
    8
    Anyone here fills up with regular gas?
    As frowned upon as this may be on the forums here, I would still like to know if any SI owner does this.
  2. webby
    • 2020 Toys For Tots
    webby Administrator
    52,155
    It will run by pulling timing to avoid knocking. It will reduce horsepower and torque when it happens. Will it run,... yes. Is it supposed to run on 87,...no. In addition to power being lost, you'll also hurt fuel economy by running 87. The $2-3 dollars a fill up for premium makes up for difference.
    Nix likes this.
  3. bauer311
    • Supporting Member
    bauer311 Supporting Member
    3,083
    Fayetteville, NC
    Vehicle Model:
    Body Style:
    Hell, I run premium in my '15 ex. I was paying so much for regular in ny, when I moved to colorado it was still cheaper and it keeps my mpg up compared to the regular they put in the car when I bought it.
  4. NoMoreNissans
    NoMoreNissans Well-Known Member
    512
    Ottawa, Canada
    Vehicle Model:
    Civic LX
    Body Style:
    there is zero benefit to putting higher octane in an engine that isnt designed to make use of it
    squiggy likes this.
  5. bauer311
    • Supporting Member
    3,083
    Fayetteville, NC
    Vehicle Model:
    Body Style:
    That may be what a book says, but seeing is believing...That's the only reason I continue to do it. I suppose the argument could be made that different people have different experiences. Or that the quality of the gas I had before was poor, I dunno, just doing what works for me.
  6. NoMoreNissans
    512
    Ottawa, Canada
    Vehicle Model:
    Civic LX
    Body Style:
    well look at it this way, even IF you're getting more miles per gallon on premium, you're paying more per gallon at the pump!
    not tryin to be a jerk I just dont want you to waste money. you likely work hard for it
  7. Enigma346
    Enigma346 Well-Known Member
    225
    Virginia Beach, VA
    Vehicle Model:
    Body Style:
    That explains some things. By using premium again, it will put timing back as well as the HP and torque?
  8. webby
    webby Administrator
    52,155
    Yes. The ecu adjust things automatically. If you run premium you'll get the hp/tq and fuel economy back.
Share This Page
