john valetutto
- 5
Hello,
A month or two ago I made a thread about excessive oil consumption on my 2012 civic si. I got allot of feedback and I really appreciated everyone's advice and input. My old thread could be found here:
http://9thcivic.com/forum/threads/2012-civic-si-oil-consumption.15724/
I have a minor update and was wondering if anyone could give me some sage advice on what to do?
Today I decided to just spend the $200 and get a compression and leakdown test just to be sure of what was causing the oil loss. The honda tech said my compression was pretty good at around 200 for each cylinder. Also he said the leakdown test wasn't too bad either with only 7% leaking on each cylinder. He also showed me some pictures he took of the valves covered in carbon and a vertical scratch in one of the cylinder walls. He said the scratch could attribute to some of the oil loss. He also said there's no way to tell how bad the scratch is without removing the head which is a 6 hour job and he can't guarantee that it could be honed out.
what do you guys think? should I just keep an eye on the oil level and just ride it out? can I use some kind of fuel additive to try to remove some of that carbon on the valves?
Here's a link to the pictures the tech gave me:
View: https://imgur.com/a/jvBREbH
