I have the sportline kit and not the Pro Kit; which is a 2 inch drop front and back, you can call Eibach and pre-order the Sportline Kit, they're not out yet but should be out by the end of September.
Here's some information regarding my camber setting:
The front camber with the sportline spring was about -0.2 degrees. This is well within specification by Honda (-0.57 max). Front caster is 5.8 deg. (5.87 max per Honda). Front toe is adjusted to factory spec at 0 deg. You do not need the camber bolts, but the camber bolts are available if you want to make adjustments.
The rear camber is -1.2 (-1.37 max per Honda). We have the rear camber arms installed. This is required. Rear toe is adjusted to 2mm total, per Honda spec.
Thanks! great info! i thought they werent out yet how do you have a set already?!
